Hi folks,
I'm still having trouble with that grill I'm working on. I don't get enough time to work on it so I'm trying to solve the problems slowly.
After buffing this weekend I noticed that there were some really really fine marks in the metal. I could see them with a magnifying glass or with a digital picture. It looks to me like possibly scratches from a DA but too fine and no real pattern. One of the guys who polishes aircraft trim said to only use a circular on aluminum.
So I went back to my circular. Here's the problem. I started getting what looked like color stains. When this happened to me initially a few weeks ago I thought at first the piece was corroding from rough sanding and leaving it too long. Then I read a product sheet on isopropyl alcohol which I was using to clean between steps and it said that it was incompatible with aluminum. So I thought I had checmical discoloration. Finally, I thought maybe the hook backing on my sanding backup plate may have dipped too close and burned the plastic into the metal because it was hard to get out.
I sanded like crazy and it appeared the only thing that got the marks (or discoloration) out was some kind of really fine emery cloth from my "assorted" sandpaper box. The discoloration wouldn't buff out with a wheel and black emery, and buffing just looked dull in that area. After the emery sandpaper and progressive grits and the discoloration was removed it then buffed up nicely (but still with the white streaks we were talking about before).
This weekend when I decided to put some 800 grit on the circular and go back over the already polished area to see if I could get out the fine pattern I wound up getting that staining color again. My circular sander is a 6" disc running 2000 RPM which is probably fast. But I knew that going in and I just glided over the surface with no pressure at all moving at a medium speed....and I only went over it once - back and forth! When done I had this big dark colored spot and something that looked like a heat burn around it. In fact, as I moved to the next area (a spot between the lettering on the grill) I could watch the discoloration appear before my eyes.
Has anyone ever experienced this before?
I knew I was going to be in for a horrible time trying to remove the spot but just for a gas I put some mineral spirits on the part and ran over it again with the sander and it started to pull some of the dark spot out which I thought odd because the mineral spirits or alcohol or soap and water on a rag won't take it out. Of course my sandpaper clogged in two seconds because it was dry paper.
I was also wondering if heat previously applied to the back of the part could cause this? I have heard that heating aluminum can cause problems for anodizing too. I know that it was heated at one point to remove some old paint in the lettering. Or am I just running my rpms too fast? Would I be better to use an aluminum cutting fluid and slower speed?
