I am currently working on an R1 frame and have had trouble getting that mirror shine that i see on some other bikes. I have little experience but i know the basics. this was my process....
Sanded with 180 all the way through 2000 using water and cleaning the surface with enamal reducer between switching grits. I then started with black compound on a spiral wheel. Then moved on to the brown compound with a spiral wheel and then white compound with a loose wheel. the problem in the end is that it looks hazey and i can see the fine scratches in the metal. I cannot feel the scratches but i can see them. the smaller areas of the frame look nice, but the large area is the main problem. I use a Millewakee drill that runs at 2800 RPM,s. does the tempature of the metal have any affect? Any help would be greatly appreciated. Also, I dont think it is a compound build up problem because I use the enamal reducer before and after each step.
