I started working on my wheels. I have wetsanded to 600 grit, and I had a very even finish. So I started working with the black compound and a 4" spiral sewn wheel with my drill (running at 3100 rpms). Now I'm getting alot of uneven scratches and swirl marks. Is this normal? Do I use only cutting motions with the black, or should I do both cut and colour motions? Will these swirls come out? Or will I have to go back and wetsand at 800 grit? Keep in mind that I'm not done with the black, I have to even out the finish some more. Thanks for your help!
