I have this piece of aluminum that was pitted pretty badly, dented, etc. I worked it for 2 days with 80 grit papaer to clean it up. So after i do this and it's nice and smoothe i begin to hit the piece with a spiral and the black emery. I did a small area for about 45 minutes and finally it began to get shiny BUT it had an orange peel look to it. I held it in the light and you could also see my sanding marks from the 80 grit. What am i doing wrong here?
Should i be using a smaller grit?
Re: Should i be using a smaller grit?
Originally posted by 92 Black typhoonI have this piece of aluminum that was pitted pretty badly, dented, etc. I worked it for 2 days with 80 grit papaer to clean it up. So after i do this and it's nice and smoothe i begin to hit the piece with a spiral and the black emery. I did a small area for about 45 minutes and finally it began to get shiny BUT it had an orange peel look to it. I held it in the light and you could also see my sanding marks from the 80 grit. What am i doing wrong here?
