What is this finish called?
  • machone
    Re: What is this finish called?
    Jeff, I'm a toolmaker & I do it like this:
    Cut a piece of wooden dowel & chuck it up in a drill press. Take some rubbing compound & apply it to the dowel (just dip it in) turn the drill press on low-medium speed 100-200 rpms will work. hold the part on the table with your fingers (CAREFUL!) Bring the dowel down onto the part, not too hard. Move the part a little, press it again. Do this in any pattern you want, with a little experimenting & practice, you can make some cool designs!
    have fun!
    mach
  • JeffL
    Thanks....I'll check it out
  • pickleboy
    also known in the firearms circles as jeweling.
  • seanc
    It's called "Engine Turning"
    Do a google search, lots of web sites are out there.
  • JeffL
    started a topic What is this finish called?
    I don't know the name or tools that are neede to produce the finish.....here goes.The entire surface is multiple swirls,not deep but enogh to make them stand out.What is this called, & how & what is neede to do this?.....thanks to anyone that knows what I'm talking about.
