First off here's what I've done so far.
palm sanded to 220 grit (can find finer hook and loop around here)
wetsand to 600 grit.
4" sprial sewn with emery
4" sprial sewn with tripoli
4" loose cotton with white
I'm doing all this with an electric drill with a max speed of 3100 rpms.
I've tried to go in one direction, then switch 90 degrees. I've also tried to use both cut and colour motions with the drill.
I've looked back at my pictures after finishing with the emery, and my finished product (white) still has the same scratches as after the emery. Pickle suggested before that I wasn't using the correct heat/pressure, and to rake more often. I tried to do this but I'm still not getting results. When viewed at an angle the wheel looks great, but when looking at it straight on it's very hazy and full of scratches.
Should I got back to the emery and spiral? Is the equipment I'm using going to cut it? or do I need something faster? Please help!
