trying to polish some stainless on a race car trailer wet sanded a spot it has some kind of coating on it what is the easiest way to get this coating off thanks
polshing stainless
Re: polshing stainless
welcome to the forum first off. not doubting you on this but what leads you to think it has a coating on it? some stainless alloys have been passivated to help the outer shell be more corrosion resistant this can create a skin if you will on the outer face of the metal. this may be what you have. if that is the case then just sand it down and start to polish like any other piece of metal. if it has a clear coating on it like some powder coat or paint then it should be stripped with aircraft stripper. then polish as normal. hope this helps bro.when in doubt polish it out/ why replace it when you can refinish it
sounds like it may have been clear coated. i would try the aircraft stripper unless someone with lots of stainless experience hasseen this before and knows different.when in doubt polish it out/ why replace it when you can refinish it
