This sidecover was leveled with 120, then I used 220/320/400/500 & 600, all on a plam sander, Everything after 220 was wet-sanded. Then emery/bias-cut, emery/loose, and white/loose.
Still it has horrible shadows, almost like metalflake under the surface (which is completely mirrored except for this problem).
Any suggestions, ideas, ever seen it?
Some of my research indicates that once you break the surface of a cast item, you're always into micropores - whether they show up only depends on their size and shape.
I can't wait to explain this to my customer...
