I just recently purchased some blasting equipment because i am sick of doing everything 100% by hand. I am polishing mostly cast aluminum and i was curious as to the best way to blast it to get it to the smoothest point possible. I was thinking of getting the coarse 100 grit glass bead then after using that switch over to a extra fine glass bead then from there to wetsanding before the final polishing. Is this the right way to go or should i use a different approach? Please let me know so i can order from caswell asap.
Thanks
Thanks
