never used
I didn't actually use it I just mixed it up and whenever I need to I take a little bit from it and create a paste to spread on to the workpiece. Can you give me an approximate of shelf life? Thanks in advance.
annodize stripper
It's difficult to say how long it will last, you might have to add some more
chemicals, depending on usage.
You can use any pad, as long as it fits, but we don't sell them, sorry.
annodize stripper
Caswell, how long does your anodize stripper last on the shelf once it has been mixed with the water. I am not getting the results I used to any longer. Also can I use DA SANDER sanding pads with the handheld buffer? If so, do you sell them?
Tags: None
