i am polishing an aluminum part with a dremel and small felt tip. after i polish with the black the surface is shiny but bumpy. they look like small rolling hills. in other words its not flat. am i useing to high of a speed on the dremel maybe im applying to much pressure. any help would be appreiciated.
need help
Re: need help
Originally posted by UFpball7i am polishing an aluminum part with a dremel and small felt tip. after i polish with the black the surface is shiny but bumpy. they look like small rolling hills. in other words its not flat. am i useing to high of a speed on the dremel maybe im applying to much pressure. any help would be appreiciated.
Some pics of the part might help us help you better. Depending on how rough the surface is to start out with, you may not need to go as low in the grit range with sanding. (Which will save you time and energy.)"Some people are like sandpaper: they may delight in the misery they inflict by rubbing up against you, but in the end you will come out smooth and polished while they'll just be ugly, wrinkled, and used up." - Beyonce Knowles
Re: need help
Originally posted by thesoundSome pics of the part might help us help you better.when in doubt polish it out/ why replace it when you can refinish it
