Originally posted by UrineMachine
An alternative to the greaseless compound mentioned would be cartridge rolls. These will take some getting used to and some skill development, but I prefer them when possible because waiting for the greaseless to dry is a royal pain. If you do use cartridge rolls, get a variety of shapes and sizes. Get 120, 220, and 320 grits. You'll need a special 1/4" diameter mandrel, which will fit into a $20 air die grinder. Using grinder's grease with the rolls will make them cut smoother and last longer. If they leave scallops, use the greaseless compund afterwards to smooth those areas. All the above is available from Caswell.
After that it's on the emery compund with felt bobs and whatever sizes of cotton wheels you need to get into the small areas. Treated wheels will last longer and cut faster. Your coloring with white compound should be done with loose cotton wheels and felt bobs.
Feel free to ask more questions. By the way, if you could use smaller pictures next time it would be good - some of us are still on old-fashioned dialup.
