aluminum wheel stripping?
  • aluminum wheel stripping?
    What is the best abrasive/tool to use on an air tools to smooth or remove paint in tight areas found on aluminum alloy wheels? Preferably with variable grits.
    I have a method of machining the flat surface of the wheel very quickly but the interior angles are difficult to smooth and sand to a paintable surface quickly. I have buffs and polishers of different shapes but I really need a tool that can form to any shape and have variable grits avaluable (reach tight areas). Thanks for any input!
    Re: aluminum wheel stripping?
    Have you considered a die grinder? It holds a 1/4" shank. They come in straight, 45* and 90* versions.
    SS
      I have diegrinders but have not found a good end brush that works well for my application.
        renuwheels,
        Try this link!
        http://www.cratex.com/
        John
          Build a PA-Blaster and run it at about 60-psi (to be gentle on the aluminum) DONE !
          Best part is you make it from JUNK !
          Sorry.. not much of a salesman.. But 840 members think so..
          DIY Groups Powder-Coating - Metal-Casting - Metal-Chipping - Metal-Polishing - Fiberglas - CNC Tables - GOT LINKS?
            ya i got the plans from him bult mine. work allsome best 8 bux i have spent
            and so simple no cloging studdy flow of medea.
            erik
