Ok,
So i'm mainly polishing aluminum parts for a car... (manifold, turbo housings, misc parts).
So I've used a sisal wheel with black emory bar, cutting is actually pretty good, and takes out lots of the scratches. Very happy with the results this gives.
My question is after I apply compound and everything gets cloudy on the metal should I stay in that position until the metal starts to polish up (clear and return to a mirror state?)
When i'm satisfied with the results of the emery bar I move on to a yellow bar (which is supposed to replace a white bar) Not quite sure sine there is no info on the website but the caswell rep in canada was convinced it's better then white. I use this compound with a denium wheel and it gives a nice shine but how do I keep the rest of the metal from clouding up after applying the compound? Do I clean the material by hand after polishing with a clean rag? Should I be cleaning the item before moving on to a new compound?
Finally I don't really see the use of the loose coton wheel over my denium wheel, doesn't seem to give better results?
Thanks for the help!!
