I started about 2 weeks ago polishing everything that I could on my motorcycle,first few days I used sandpaper 100 grit all the way to 2000 grit then onto 10,000 grit wool,finishing with a polishing kit from dremel which came with felt bobs,wheels and rouge,to do 1 side of the wheel it took me about 20 hours,had to be a better way so I found this site
,bought 8 sisal wheels,6 spiral,4 loose cotton,120 grit greaseless, black compound,brown compound,white compound,assorted bobs,finally get my shipment and start with coating a sisal wheel with 120 greaseless,let it dry as per instructions, and go to work, its taking longer to remove casting pits and marks with wheels then if I were to do it by hand,am I doing something wrong I am using 6" Wheels on a 19.2 volt cordless 1/2" porter cable drill,I do own a 1 H.P. variable speed grinder but it would be difficult to hold the wheel up to it for so long.any assistance would be greatly appreciated Thank U
