flexible shaft polisher/sander
  • flexible shaft polisher/sander
    I'm trying to polish the frame of my zx9r.Does anyone recommend a flexible shaft polisher ? If so, what brand and model. Also when prepping the frame, do I need to do the whole sanding thing or can I start with the greaseless compounds to remove the sandcast and smooth down the welds?Thanks for the help
    I have caswell's flexible shaft. Works great for the small areas using felt bobs. Always start with greaseless. They will save you hours of work.
