Does size really matter?
  • Does size really matter?
    I looked up the aluminum polishing kit to polish some stuff on my bike and my IROC wheels. The kit comes with 4" wheels. I read in the search that it takes more to buff with smaller wheels. Can I use a 6" or 8" wheel with my electric drill?
    Mark
    It's all about SFPM:
    For best results your wheel should maintain a surface speed of between 3600 & 7500 Surface Feet Per Minute. (SFPM). The higher your speed, the better and quicker your results.
    Formula for calculating surface speed of wheel in SFPM.
    SFPM = 1/4 x diameter of Wheel x RPM (revs of spindle per min.)
    Therefore an 8" wheel @ 3600 RPM =2 x 3600 = 7200SFPM.
    However, your drill may not be able to spin 6" or 8" wheels because it may not have enough power. If you can press a wheel against the part you're buffing without stopping the motor, you're safe.
