How to remove aluminum coating on aluminum base material
  • How to remove aluminum coating on aluminum base material
    I might be in the wrong frum for this but I'm desperately seeking for answer.
    Can anybody suggest how can i remove aluminum coating (thru arc spray) on aluminum base material?
    I tried sand blasting usng white aluminum oxide but the coating bond strength is really strong.
    Chemical stripping without harming the base material? Did anybody try before?
    Please advice. Thks!
