yo im in the process of starting to powder coat and i have a few questions about sand blasting and glass beating. What exactily is the difference of them? I mean i know what they are and stuff but what is better for taking off dirt and making it extra extra clean? Also if i get a glass beater can i use the same gun for sand blasting? Say if i wanna remove paint from somthing what would i use? What would i use to clean the metal?
Sand blasting VS glass beating?
They will both work to strip paint. Sand does not give you the nice gray clean aluminum finish if you know what i mean. Parts tend to have kinda a yellow tint to them when you use sand. If your painting then it wouldn't matter anyway though.
Re: Sand blasting VS glass beating?
I've heard not to glass-bead aluminum then try and powder-coat it as the glass shards/dust will get in any microscopic hole in the aluminum and screw up the powdercoating process..
coal-slag on the other hand wont..
I wonder what copper slag would do?DIY Groups Powder-Coating - Metal-Casting - Metal-Chipping - Metal-Polishing - Fiberglas - CNC Tables - GOT LINKS?
