Brass trumpet plating? Need advise please
  • Brass trumpet plating? Need advise please
    Hi guys I acquired this 100+-year-old trumpet recently. The silver portion is made of Britannia metal that has been plated. The black coloring on the lower portions of the trumpet is where the plating has worn away over the years. At some point in its life I assume it was dropped and the top portion was damaged. Someone replaced the top portion securely but with brass as you can see. Is it possible to have the top part re-plated after I engrave a design to match the rest of the piece?
        If there is if I a way to upload a clear picture please let me know. When i try to upload a nice clear shot the forum says its too large.
          You should be able to plate this, read through our plating manual for detailed instructions.
          Jason Vanderbroek
          315 946 1213 x116
          www.caswellplating.com
