Removing Nickel plating
  • Removing Nickel plating
    Anyone have experience removing nickel plating? Can this be accomplished by using the same equipment and solution used for nickel plating and just reversing the power supply leads?
    I have some old cast iron skillets that I want to remove the nickel plating from. Any help appreciated. Thanks.
    You would want to use the B9 Nickel stripper. Never use your kit to remove old plate, you will end up with contamination issues.
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
