I tried the black oxide kit for the first time today. I ordered it with the dry sealer.
While hanging my knives to dry I noticed they have a shiny area at the tip, which I'm guessing is from the sealer running down to the bottom areas of the knife and building up while it was hanging. Is there a way to prevent this other than trying to shake the sealer of better? Should I wipe it with a cloth or is there a better method to keep this from happening?
I know it's a minor issue that probably has a simple fix, but I'm going to re-bead blast this and try again. I know everything has a learning curve, but I'd rather not have to redo it a bunch of times if I can help it before I figure out the best way to go about blackening my blades.
Thanks.
Thanks.
