Nickel plating on an antique
  • Nickel plating on an antique
    I am restoring an old desk, and it has a makers nameplate on it. I stupidly assumed it was solid metal and went to polish it with fine grade sandpaper (#800), and polished through the plating. Several days later, I've finished swearing at myself for being such an idiot, and now I'm looking into what I can do about it. If possible, I would like to carefully restore the nickel on the areas I have sanded.
    It's from 1870 and it looks to be nickel plated brass. I can't take the plate off the furniture, so anything i do has to be done in place. There is no copper layer between the brass and the nickel, so I'm thinking it might be electroless nickel plating. Is that a good theory?
    Is there a suitable plating process I can use to carefully restore some nickel onto the surface, without risking further damage to the plate? I've done a bit of electroetching and electroplating before, but I don't know anything about electroless plating, and I don't know what would have been used originally in 1870. I'd love to hear some thoughts.
    You can restore the nickel with the Nickel Brush plating kit. You will need to activate the old nickel layer adjacent to the damaged area.
