Dipping Vs Spraying-Using Black Oxide Concentrate to darken or (gray) the steel
  • Dipping Vs Spraying-Using Black Oxide Concentrate to darken or (gray) the steel
    Can the 9:1 diluted black oxide concentrate be sprayed on/brushed on, or does it have to be dipped?
    More detail:
    Is it possible to mask off an area you do not want to oxidize, and then spray or brush the Diluted solution onto the area you want to oxidize? I am hoping for a dark gray look instead of the full black look.
