Can anybody render an opinion on some of the commercially available rust removal concoctions that are now available, particularly Rusteco, Evaporust, and Safestrustremover.com. Thank you for sharing your experiences.
Rust removal potions
Pickle 2 is 1 part HCl and 2 parts distilled water. This terminology is out of the Caswell manual. The HCl is simply the grade commonly avaliable from Home Depot as Muriatic Acid. I believe it is a 31.45% mix as purchased.
Kind regards,
Ken
Permatex makes a nice naval jelly #81756 that can be used to remove rust in the presence of plating. The plating is relatively undisturbed and the rust is removed. I use this when a customer wants a part cleaned up but does not want to pay for replating. I buff with white compound afterwards to remove the slight tan staining that the formula leaves on the plated area of the part. The results are quite impressive...although obviously you still have an area left unplated.
I've also done this followed by replating. Since it's much gentler than hydrochloric acid, the rest of the plating stays intact and the amount of prep work is minimal. Again, the results are somewhat of a compromise vs. stripping and restoration, but sometimes this is all that is requested.
Ken
