Acid Dip For Brass Before Silver Plating
  • Acid Dip For Brass Before Silver Plating
    Hi
    What is a good and readily available acid dip for brass before plating silver.I asume the acid step mentioned in most plating literature is about the same as a metal activator? Any help is appreciated.I am currently using an ACID DIP made by Midas it comes in powder and has to be mixed with water.Problem is it leaves a residue even after a pretty heavy rinsing under water. Anyone know of a better ACID DIP that won't cause such a problem with residues?
    Thanks
