Hi all..
Is there a way of producing a stainless steel look on metal parts.
I'm currently building a Radio Controlled 12th scale model of an RNLI (Royal National Lifeboat Instutition) Mersey Class lifeboat which has a number of stainless steel parts. I wish to keep the look as authentic as possible hence the question.
I've read something about using Nickel and antiquing it but I'm not sure what that means. The Nickel part I understand but the Antiquing bit I'm not sure.
Also, does it matter what metal the part is made from?
My reason for asking is that most of the parts I have are cast in White metal. Will Nickel plating work with white metal castings? I'm also looking at casting with Brass and Aluminium as the Whitematal for some of the parts is quite soft.
Help greatly appreciated.
Declan Barry
N. Ireland
Declan Barry
N. Ireland
