Can I use VHT high Temp with Krylon High temp radiator paint
  • Can I use VHT high Temp with Krylon High temp radiator paint
    I am spraying my valve cover (VHT high temp Clear worked great in the past year) and I would like to get some different tones working. VHT Gray and silver are the same exact shade, just there's a little metallic flake to the silver (very little).
    CAn I mix and match Krylon High heat & Radiator paint under the VHT clear?
    What about mixing the 2 brands to creat my own shade?
    Thanks!
    Magnus
    Test it on a junk piece first.
