I'm having some difficulty getting a clean finish with the Silvachrome. About what PSI should I be using? Does anyone else have the problem of overflow streaking the surface of the item your attempting cover with Silvachrome? When they say 70 degree temperature helps, does this refer to the air temperature of the air from the compressor or the temperature of the surface your spraying?
It seems the only way to get good results is to stop any droplets (overflow) from forming on the sprayed surface. Any suggestions?
Thank You.
Thank You.
