After curing a part in a oven, should the part be remove to cool or stay in the oven with the oven shut off to cool?
After Curing
Cool down
Would you allow a part to cool down in the oven if you are using a large oven (ex:96 cu ft int.) and then reheat the oven? Also on base color that you are shooting a second coat on (I have found that a semi-hot part takes a second coat better), do you let the part cool in the oven then or remove to a warm temp and then second coat.
I let it cool in large ovens too. and if a second coat is needed i will let the part cool only if the second coat is a clear coat. i just been doing it like that aways in the big oven. my big oven is 6Ft long, 3.5Ft tall, 2.5Ft wide. takes a little time but i want to make sure it's got a wet look to it or something like that. if not then i will have to remove the coat and do it all agin.WARCHILD
