I'm planning to have the chrome exhaust pipes for my 71 triumph replated. I want to prevent blueing. Is there a thermal coating that can be applied to the interior of the pipe to prevent absorbtion of heat. The blueing only occurs at the downward curve close to the exhaust port. so the entire interior of the pipe does not need coating. I was thinking about this product: "CBC1 POWERKOTE (Cermet Coating Thermal barrier)." I do not have any powdercoating equipment or supplies. I would appreciate any suggestions. thanks, Scot
prevent blueing of chrome pipes
Re: prevent blueing of chrome pipes
Originally posted by PennsyScot View PostI'm planning to have the chrome exhaust pipes for my 71 triumph replated. I want to prevent blueing. Is there a thermal coating that can be applied to the interior of the pipe to prevent absorbtion of heat. The blueing only occurs at the downward curve close to the exhaust port. so the entire interior of the pipe does not need coating. I was thinking about this product: "CBC1 POWERKOTE (Cermet Coating Thermal barrier)." I do not have any powdercoating equipment or supplies. I would appreciate any suggestions. thanks, ScotEMAIL [email protected]
CBC1 is a waterbased coating for piston, this is not the one you should have inside the pipes, for one, you wont even get it in there. If you go with Techline coatings you would want the TLHB as its made just for that application.
Blast inside, cover all holes but one, poor the coating in, cover it fully, swirl the pipe around and poor the leftover out. Let dry fully before curing in the oven.WEIRD Performance & Coatings
Sweden
