at the moment we are using a 8 metre oven ( made by maywick)
fired by 48 gas ceramic burners with a conveyer running though the oven
oven temp is 380c this is a lot higher than the powder coating temp of 180c ,we bake the powder coated parts for 4 mins any longer and we find that the parts burn or discolor,the finish we get is ok but we find that the power is not very tough (marks easily) we use polyester powder from du pont
The oven temp is very uneven starts at 30c one end increases to 380c other end
any suggestions to get tougher paint finish
thank you
thank you
