I just went through my first powder coating project. I'm using the Harbor Freight gun system and a normal kitchen oven that I use outdoors just for powder.
I applied some high gloss black powder to some 68 pontiac hood scoop inserts (I think they are cast peices...not sure though). I cured the pieces at 400F for 10 minutes as specified and ended up with horrible orange peel....I sanded with 1500 wet and still couldnt get rid of the peel.
The oven was soaking at 400F for 30 minutes prior to parts being inserted. I let the parts cool in the oven with door propped open and oven shut off.
I prepared the parts by sanding to bare metal with 220 grit and then cleaning with laquer thinner.
When I applied the powder, I believe I got good adhesion because the powder attached itself to the parts with great uniformity.
So, after my first attempt with the bad orange peel...I sanded the black powder coat with 400 grit wet and heated the parts for a while with a hand held heat gun and finally I reapplied the black powder coat. I used the same cure process and achieved better results than the first attempt...but there was still orange peel present.
So now I have stripped the parts back to bare metal and I await some suggestions from u guys on what I could be doing wrong.
Any opinions or help you can offer is appreciated.
Unfortunately, I bought the powder of of eBay (from an individual not a company) so I cant be caertain of its origination or quality.
Thanks,
Eric
Thanks,
Eric
