I made a sand blasting tent.
  • I made a sand blasting tent.
    I'm a hobbyist with a limited workshop and needed some blasting done. I built a simple frame with PVC and stitched together a Tyvek tent.
    I'm not sure why no one makes a commercial version of this. Sized to sit on a folding table and set up in very little time. Zippers were sourced from discarded soft luggage found on the side of the road. They TYVEK is a perfect material for this. Tyvek is super strong, relatively cheap and sews nicely. I tacked together with hot glue tabs and then sticched with a small Brother sewing machine. The window is from Acrylic from Tapp plastic and sits on a nice repurposed carbinet face frame that sliced in half. Lit on the inside with a LED shop light.
    Works great. pics here...
    some pics of the build here..
    Total cost- well under $50
    https://goo.gl/photos/cT5kg81TL1ZdN9TH7[1]
    And it's the size you need...nicely done!
