Zn-Ni Plating
  • Zn-Ni Plating
    Hello
    I got a Zn-Ni plating bath and when I am setting up the bath (1.5 Gal of DI Water, 1 bag of Zn-Ni Crystals, 1/2 teaspoon of Zinc Brightener) I mixed very well. If I finish the agitation some white powder is precipitating and the solution turn green. At the same time in the instructions I can not see any suggestion about temperature or agitation so, these is not necessary? I hope be clear with my questions and I hope someone can help me with this.
    Thank you
    Use hot water for the initial make up, then use the made up solution at room temperature. Our Zinc Nickel is Green.
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
