This may be a little off-topic of the forum but I knew someone here would probably know the answer. If you know of a better forum to try this out on please let me know.
I'm going the route of creating a blasting room since I'm stuck working with some rather large items. Now just 10 minutes ago, fingers aching with pain, while I spent my forth hour sanding a piece of abs motorcycle fairing trying to rid it of it's existing paint the thought of blasting the plastic hit me.
Is it possible to sandblast ABS and fiberglass as an alternative to heavy-to-mid grit sanding? Heck, can it even take the place of finer grits (1000-1500) too? That would save me days of work!
Anyone seen or done this?
