Hello,
I have a few questions about sandblasting before I make any purchases. I am new to the Sandblasting/Powdercoating scene and I have done my share of
research but I just want opinions about what to buy.
I am looking to Powdercoat automotive parts. Like for example rims, intake manifolds, valve cover etc....
I know about all the prep and the sandblasting necessary for a good powdercoat job to be successful.
Heres my question:
Will This Set-Up Work for what I want to do?
10 Gallon Tank Hot Dog Pneumatic Portable Air Compressor 3 5HP Motor 125 PSI | eBay
3.5 peak horsepower .
Durable cast iron cylinder.
Oil-lubricated motor for long life.
Delivers 7.2 CFM @ 40 PSI, 3.5 CFM at 90 PSI.
125 PSI maximum pressure
with an Ebay Sandblaster
Portable Handheld Air Sandblaster Sand Blaster Kit Rust Paint Remover w 4 Nozzle | eBay
Portable sandblaster kit
Comes with (4) nozzles
Handles glass beads, sand, aluminum oxide or other abrasive materials
Minimum air compressor requirement: 3HP & 90 PSI
30LB capacity seamless polyethylene hopper
5 feet rubber hose
Heavy duty sandblaster gun with hardened steel nozzle
Let me know what you think!!!!
Thanks
Heres my question:
5 feet rubber hose
Thanks
