WHICH BLASTING MATERIAL SHOULD YOU USE FOR THE 1ST TIME
  • WHICH BLASTING MATERIAL SHOULD YOU USE FOR THE 1ST TIME
    im in the process of getting everything ordered for my first venture into powder coating, i will be doing some scrap piece then moving up to some atv parts
    so what would anyone reccomend, i had saw some threads on this kinda but i guess i didnt know enough about it yet to get what i needed from it
    brandon
    Black Magnum, Black Beauty, coal slag, cheap stuff (all the same thing!)
    Hemi-T
      Slag works great, i use only fine and very fine grit.
        hmmm, my supplier only carries medium B/B
        cheers
          Slag is cheap and blasts a nice profile. If you can find it local, use it.
