I'm building a pretreatment tank(dip tank) and need to heat the iron phosphate. I'm using a 30 gal steel drum(new) on it's side and need to find a submersible heater that can keep the contents at around 100 f. I doubt a fish tank heater will do the trick as most that would be big enough will not hold the temp above 78. I thought of using a hot water heater element and thermostat but would rather use a real submersible heater. I'm also at the end of my budget, so money is getting tight. Please help!!!
pretreatment tank
Have you though of using tea kettle elements. Maybe like 3 or 4 would do the job. You could probobly find some nice doners at the local Salvation Army or thrift store. The only difficult part would be hooking them up some type of thermometer/on-off device.
etyrrany
http://www.caswellplating.com/supplies/heaters.html
there ya go. 17 bucks and it should do what you're looking for. The plating guys use em all the time. Hope that helps.... Russ
By the way.... welcome to "da boards".
Wow that was fast. Thanks for the replies.
etyrrany: I was going to use a heater element from a water heater but decided against it because of the wiring and temp control problems. I even looked at some of the hamilton beech electric dutch ovens in Wal-Mart.
non-stick: Thanks for the welcome...I've been lurking for a while...I'm really just getting restarted in PC and this forum has been a great help. I hope I can contribute to this growing knowlege base. I saw those heaters and wondered if they would heat about 25 or so gals or would I need a few of them? My biggest problem is volume. I've found heaters that will do the job but they're very pricey. I will post some pics of my setup when it's done so maybe others can copy it.
It would be best to invest in a 1000 Watt Heater. We can supply them, with a controller unit, for approx $300.00. I doubt our 300W heaters will get that amount of solution up to temp.--
