polished aluminum
Polish the wheel to desired level and then powder clear.When done right you realy don't even see the clear coat. I've done brass the same way and when done, people can't even tell it's coated till I tell them.
polished aluminum
Hi everyone, I'm the new kid on the block. I just had a couple of question on clear coating a polished aluminum wheel, such as a weld racing wheel.
I guess first can if be done with good results?
How would you prep the wheel and still keep the shine.
DavidTags: None
