Anyone try using a laser printer to create designs for powder coating?
I was wondering if you took all the toner out of a laser printer and replaced it with Poweder Coat powder, could you then print a design on something, then bake it for the powder to set?
You'd have to modify the printer so the powder coated part did not go through the printer's fuser. Instead, you'd just take the part with the electrostaticaly adheared powder coat powder to your oven for standard curing.
I gotta try this.
I gotta try this.
