Hi,
During the past weekend I was experimenting a bit. I was doing a mirror chrome base and a candy teal top coat and I got a bit of an error. The metal substrate is a section of chromemoly steel pipe that I salvaged from my now defunct bicycle.
The process was to strip the old paint, sandblast with Alum Oxide at 90PSI and clean with IPA and shoot with Mirror Chrome powder. Note, the part was not pre-heated! The part was baked/cured at 375?F for 20 min. Then let air cool for 5min and shoot with Candy Teal which was baked/cured at 350?F for 20min.
This is the result I got:
The areas circled with the red I know what that is. That is the left over lint from the blue shop towels that I used to degrease with IPA. The rest of the little craters I have no idea that it is. Since this is a ferrous metal I am assuming that you do not have to outgas. The little craters do not look like they are they typical outgas problem. I believe that the little craters were evident after the Mirror Chrome was shot but I am not 100% positive. I only noticed them after shooting with the Candy Teal.
I did another sample with the same metal. This included a polished section of pipe that I shot with just Candy Blue and even without preheating it came out flawless.
So my question is what is it and how can it be prevented.
Thanks,
etyrrany
Thanks,
etyrrany
