Powder Coating over chrome plating
  • Powder Coating over chrome plating
    Hi,
    Can you powder coat over chrome plating , is there anything
    special you have to do to prep it?
    Thanks,
    Art
    Art in Peterborough
    All I do is give it a blast, to give the coating something to adhere to. You can also put some of the transparent powder right over it without blasting for a really neat look. I've done that for a bunch of people.
      Just make sure it is clean of any oils right, Then hit it with a Clear top coat with say, some metal flake added for a sparkley look?
        exactly
          i sprayed right over polish ... no sand blasting it it held up good
            I used one of those scotch guard pads and sorta srub it and cleaned it with acetone, and no problems...
            Pro-Tech Powder Coating
            93976 Ocean Way
            541-247-8168
            [email protected]
            Gold Beach,Oregon
              Thats what I do and did on this piece
                what about anodizing
                can you powder coat over it without doing anything special like sandblasting or buffing
                  You can, it will coat, but you will not get as good a bond if you don't prep it properly.
                    a word of caution on adding metal flake....make sure its true metal flake, some of the metal flakes are actually made of ground polyester..
                    93976 Ocean Way
                    541-247-8168
                    [email protected]
                    Gold Beach,Oregon
