OK All you Wizards out there. When you do a multi color combo, Do you mask off the smaller area and coat the large area first or the other way around?
How long do you cure the 1st coat prior? Full Cure?
How long do you wait till you do the 2nd?
Also Preheating will let you know if you cleaned all the oil off the part. Valve covers can hold a lot of oil underneith and will smoke you out very quickly
