Does anyone recommend the Powder Thickness Guage? Or I should say what is everyones opinion on the Powder Thickness Guage? I know it says the area you check "may" affect the characteristics of the cured film. Any comments appreciated.
Gauge selection will be dependent on substrate material and physical properties andthe coating thickness target range. Ferrous, non ferrous, geometry, and tolerances will be your primary input information in a gauge search.
-ScottJ. Scott Moncrief
Manager-Engineering, R&D
Livingstone Coating Corporation
