I was just wondering what would do a good job of reflecting the IR waves back to the piece I was baking. I have a Triple Mr. Heater, I think drfjr1976 has something similar. Was thinking about aluminum foil, but was just looking for ideas. Thanks in advance.
Best material to reflect IR waves?
you might try those mylar emergency space blankets or the winshield dash protectors.
I just got back from so cal and saw a setup where they picked up some aluminum sheet from Home Depot and polished it. This allowed them to shape it for a specific part. After polishing it they just use a laser pointer to test where the light will hit the part. I notice that they used a couple of 1X2's to make the bends they needed, so it doesn't take any special tools or any special skills. The aluminum sheets were very thin...maybe 22ga.
well if you are using IR you SHOULD be using the hand held IR temp gun. Which has a laser pointer on it. As most should know the laser is just to AIM the gun, it doesnt read temps... Just a suggestion so people dont go out buying laser pointers. lol and if you are using IR and dont have a IR temp gun, GET ONE! lol
archerI Plead the Fifth!
