Motorcycle frame PC'ing
  • Motorcycle frame PC'ing
    A couple quick questions...
    1). Should I PC the entire frame at once?
    -and-
    2). I'll be using my IR lamp. Is there a preferred method of curing, i.e., moving the lamp top-to-bottom, vs. side-to-side?
    Thanks...
    Hi,
    You should definately powder coat the entire frame at once and there is no preferred method but remember heat rises.
    etyrrany
      Thanks, I'll give it a shot...
