well it is time to either get a new one or build one ...
this oven is gas fired (propane )
now here is a question.
the body it 1/8 steel skins on the inside with alum. plate on the outside
what would you think would be the better barrier in the middle .. rock wool of that foil coated board ?
this is based on a bbq burner setup ....
i did a test on a smaller box i built and i got the box up to 500f with no problem ...
