Hi all,
Just got my PC kit. Been reading up a while before I purchased the PC kit. Sounded pretty straight forward.
Prepped some test parts, made a spray box, hooked everything up..
The powder comes out in some nice huge blobs, air at 12lb as it goes to 10 as the trigger is pulled, air screw on gun screwed all the way in, system on, ground clipped, foot switch engaged, pulled trigger.
I think I could have gotten better coverage just dumping the powder out of the can.....
I pulled the trigger 4-5 times thinking just work in the gun. about 1/2 can had come out and piled on the bottom tray of the booth, (thank god I used your trick to ground a flat pan on the botton for recovery...
No way I can get an even coat out of this sprayer.
HELP
Bob
HELP
Bob
