I have been doing alot of research on powder coating because I want to start doing it at home. The one thing I have yet to find an answere to is grounding the piece to be coated. If you clip somthing to the piece to ground it how does the powder cover that section? Does it run over slightly during the cure process? Any help would be great.
Thanks
Evan
Thanks
Evan
